Discussion topic: No Broadbands
This message was authored by: Steve65701
No Broadbands
Tested via sky website, it say router, WI-FI & connection is good. I gave orange light on router with no internet. Turned on & off still orange light, sky says no issues????
Re: No Broadbands
@Steve65701 the standard advice is to check the lights on the the hub which you have done -see https://www.sky.com/help/articles/hub-lights-explained-start - If they show the hub has lost connection to the line and a simple reboot doesn't sort the issue is to log into the My Sky app and see if the service checker tells you Sky are aware of a fault affecting your line. Don't worry if it says everything is fine as that was the position when it last tested the service.
If it doesnt tell you it's a known fault call Sky their lines are open from 8am to 9pm
