Discussion topic: WiFi connection
Message posted on 11 Jul 2025 11:25 AM
WiFi connection
Message posted on 11 Jul 2025 11:28 AM
Re: WiFi connection
@Lauravic
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Message posted on 11 Jul 2025 11:39 AM
Re: WiFi connection
Done all this and says everything is working good. But it's not!
Message posted on 11 Jul 2025 11:42 AM
Re: WiFi connection
Then as stated above it might be time to call Sky to report it.
