Discussion topic: Broadband keeps going down
Message posted on 11 Jul 2025 11:57 AM
Broadband keeps going down. Have rebooted the router and disconnected everything.
Message posted on 11 Jul 2025 12:10 PM
Re: Broadband keeps going down
@DaveDaveDaveDaveJ
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
