Discussion topic: WiFi Max Hub free
This message was authored by: BAKER126
WiFi Max Hub free
I noticed they are offernig the max hub for new broadband users on the gigafast package at £44.
However my renewal is £44 with my current hub the black hub 4 why do i not get the new hub?
Re: WiFi Max Hub free
@BAKER126 simply because that is the policy nothing as customers we can do anything about. However the while the new hub does support WiFi6 it has no greater range, isnt compatable with Sky's Q tv system and has less customer controls it may beca blessing in disguise.
Confetti Ring
Avatar for BAKER126
Level 5 icon
Didn't realise it was not compatible with sky q, I have sky q . That sounds bizarre will they release one in the future which works?
Thanks for your answer.
