9
This discussion topic has been answered Discussion topic: Wi fi keeps dropping
This message was authored by: cessie
Hi I need help with my wi fi as it keeps dropping and having hearing aids that run on WiFi I keep getting reconnect ,  I have had trouble with this problem for several weeks.  We got a up to date hub and WiFi boosters but it's still happening
I have done the usual thing like turn off hub then reset it again but makes no difference I can't even open facebook
Re: Wi fi keeps dropping
@cessie
Try running the line test here to see if any faults are found:
If this is of no help then you will need to contact Sky and has you have a hearing issue you might want to get yourself registered with the accessibility team at Sky as there are then additional contact options that do not involve calling:
https://www.sky.com/help/articles/accessibility-information-sky-mobile-broadband-and-talk-customers
@cessie
Avatar for cessie
WiFi keeps dropping
I have done everything that's been suggested about my wi fi and it make no difference
Re: WiFi keeps dropping
@cessie
I've moved todays post into your original thread. Have you called Sky as suggested above?
Avatar for cessie
Hi yeah I have done all checks but still WiFi drop, one chap at sky said it was their end and will  be fixed by Friday just gone but no confirmation and still the problem exists
@cessie
Sky normally quote 2 WORKING DAYS as a potential fix time. This is the service level agreement in the UK between ISPs and Openreach for fixing a fault as Openreach claim to be successful within that timeframe in 85+% of cases. Unfortunately some take longer, especially if the repair involves the pavement or road needing to be dug up and the necessary permission from the council to do that.
This message was authored by: Marples1959
Woken up due to CCTV off line as WiFi is off line
@Marples1959
When there are broadband issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If not follow the advice already given in this thread.
This message was authored by: Poninski
My hub is conected all test are done positive but I still don't have wi fi connection
@Poninski
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
