Discussion topic: What Cable do I need
Message posted on 22 Nov 2024 12:18 PM
Re: What Cable do I need
“It's obvious because those are the only pins present, so no need to worry about colours.”
How is it obvious? A crossover is BT 2 to RJ11 4 plus BT 5 to RJ11 3. A straight through is BT 2 to RJ11 3 plus BT 5 to RJ11 4. It’s not obvious by looking at the pins. You still need to look at the colours, or put a wire map tester on it, or put a multi-meter on it.
On the other-hand, your suggestion about just plugging the original cable into a straight through extension lead is probably the best approach under the circumstances.
Message posted on 22 Nov 2024 12:22 PM
I've ordered this a straight through extension will this work with the original wire
Message posted on 22 Nov 2024 01:33 PM
@Anonymous wrote:How is it obvious?
If there are ONLY two pins present on the BT plug on 2 & 5, & ONLY two pins present on the RJ11 on 3 & 4, it's "obvious" how the cable is wired. So I said that IF the OP's Sky cable is the same, he will require a crossover.
Message posted on 22 Nov 2024 01:34 PM
@joea2001 wrote:I've ordered this a straight through extension will this work with the original wire
Should do, at least in the same socket you used originally.
