Discussion topic: Weak security
This message was authored by: elle111
Weak security
As per multiple complaints...weak security causing multi interruptions to WiFi / broadband - how do I reconfigure as I think that's what I'm expected to do?
Avatar for elle111
Level 0 icon
Re: Weak security
Completely useless non response
Re: Weak security
@elle111 the default security on Sky hubs meets all of the standard requirements by default the black hubs uses WPA2 WiFi secirity. On the white hubs that can be switched to WPA3 assuming your devices support that. The default passcodes are complex again meeting indutry and UK government standards. Why do you think "weak security is causing mutiple interuptions to WiFi/broadband?
Thecforum is a customer-to customer channel so expecting a response in one minute is somewhat unrealistic.
Re: Weak security
@elle111
Welcome to the Community. When you created a new discussion it says…
Re: Weak security
@elle111 The sky Help is a good place to start, see the link below, it may save you some time if this is what you need?
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
Re: Weak security
Are you perhaps referring to pop-up alerts on an Apple device?
