Discussion topic: Broadband is working ok but WiFi signal in 2 upstairs rooms.
This message was authored by: Darrenmc11
When downstairs near the router everything is fine, but WiFi connection keeps dropping in 2 rooms upstairs. Extremely frustrating when working from home and video calls drop. How can we get a WiFi booster in both rooms? Chat function doesn't really help and struggling to find answers on how to contact Sky.
This message was authored by: Estewart
Re: Broadband is working ok but WiFi signal in 2 upstairs rooms.
I'm having the same issue. Extremely frustrating.
Avatar for Darrenmc11
All I get from the chat is to do a test, which says everything is fine (which it isn't). Moved from BT as broadband was poor but better than this and at least could contact them.
Everything else says you can get pods if on Max package. I'm on the Max package but unsure how to request them??
@Darrenmc11 You need to call sky to get even the very 1st one! Calling is dial 150 from your landline phone, or if you have a sky mobile it's the same number.
Thanks @JimM1. Am I able to call 150 from my mobile (not with Sky mobile)?
@Darrenmc11 dialling 150 on a mobile willconnect you to your mobile provider not Sky. Dial any of Sky's numbers starting 03 if using a non-Sky line.
@Darrenmc11 No, @Chrisee answered it all for you... Post 4 on the link below click and find the number!
https://helpforum.sky.com/t5/Broadband/Moving-Home/m-p/5080372
That's great thanks both. Hopefully get this all sorted.
