Discussion topic: Was not working
This message was authored by: Norsem
Was not working
Just got brand new hub and tried connecting my printer via ups but the ups flashes amber not green and the printer will not connect.
Avatar for Norsem
Re: Wps not working
Just got new sky hub and tried to connect my printer with wps but it just stays amber and won't turn green so printer does not connect.
Re: Wps not working
@Norsem
Often printers need a full factory reset before they will re-connect.
You may also need to split your WiFi bands. Instructions on how to do this can be found on the link below.
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
I am NOT a Sky Employee
This message was authored by: sonicares
Re: Was not working
Your printer might only support 2.4ghz. Make sure 2.4ghz is enabled on your router.
