27 Apr 2021 12:15 PM
Well done, another router to add to the list of non native dhcp option 61 used on fttp ont. 😃
14 May 2021 02:17 PM
I've just set my Orbi up directly connected to the Openreach Modem (ONT)
You have to enable IPv6 on the orbi web login (cant do on the app) on the advanced section then IPv6 plug the ethernet in the internet port on orbi and the ONT and it just works 🙂
14 May 2021 03:57 PM
Has anyone had any joy with a Nest Router on FTTP? Cheers
14 May 2021 04:38 PM
As theres no need for log ins to the modem, doing this should have it up and running
25 May 2021 08:35 PM
Hi All, i am looking at this myself. Is the speed and reliable any good? I am seeing near on continual drop outs with my Q Router and boosters.
26 May 2021 06:10 AM
Posted by a Superuser, not a Sky employee. Find out more@CallMeSteve you will need to be more specific as to what you mean by "this" and what service you are buying from Sky. This because what will work with FTTP connected to a ONT unit may not work on Sky FTTC services which use a copper phoneline. This thread has got messy as people are discussing both types of service.
01 Jun 2021 10:12 AM
@DaneBC I've recently purchased a Netgear Orbi and it worked fine to begin with except the internet drops after 24 hours and then requires a rooter reboot to fix it. Sounds like something to do with the assigned IP address not renewing maybe? What settings do you have for IPv6?
I've enabled IPv6 in the Orbi web interface, but for IP Address Assignment I have selected "Use DHCP Server" rather than "Auto Config". For the DHCP Server option I've selected it mentions that "some IPv6 systems might not support the DHCv6 client function."
01 Jun 2021 12:25 PM
Oh no, I was thinking mine was faulty and was going to exchange it. I've currently got it on a smart plug rebooting at 4am each day (not the worst thing in the world) my main issue I'm. Having is what's app and Facebook messenger often don't want to connect for ages then sometimes it works fine
03 Jun 2021 12:33 PM
@Outsharked did you get your Nest Hub working (or anyone else?).
I have Google WiFi, and am just checking if it works before I switch.
09 Jun 2021 08:16 AM
@DaneBCI think I may have fixed the issue where the internet stops working after 24 hours with the Netgear Orbi.
In the Web console for the Orbi go to Advanced -> Setup -> Internet Setup and then in the DHCP section set Client Identifier String (Option 61) to "username@skydsl|mypass" then click Apply
09 Jun 2021 09:40 AM
@samfromoz You little legend
Are you having issues with whatsapp/facebook messenger taking ages to connect
09 Jun 2021 08:53 PM
Hi All, just thought I'd piggyback on this thread rather than starting a new one. I'm currently on sky broadband superfast and it's FTTC in my area. I've purchased an Asus RT-AX86U to use as a router and have the BT Openreach modem that I was given when I first signed up to sky fibre before Sky Q hub came along etc..
I plan on connecting the modem to the wall socket, then connect the modem to the router on the WAN socket. I'm seeing mixed info online as to whether I need to put anything in the client identifier value for option 61. Should I just try this or does the client identifier value need to be populated with something ? Any other config I need to make on the router ?
09 Jun 2021 09:02 PM
Client identifier needs populated as this is how sky authenticates the device . To be 100% accurate as asus can be quite picky in the format input
12 character asus mac address|last 6 digits of mac
Eg in the format
12345678abcd@skydsl|78abcd
09 Jun 2021 09:14 PM
Also bare in mind the seperate modem probably hasn't had a firmware update for ages and is now obsolete . Give it a go anyway just be prepared to having to buy a stand alone vdsl2 modem that can be put in modem bridge mode such as the draytek vigor 130.
09 Jun 2021 09:15 PM
Any tips on how to work out what those values are ? I take it the router MAC address can be found in the DD-WRT Merlin router admin config somewhere ? And what is the second mac address ?
Forgive me if the questions seem stupid - first time i've used DD-WRT and the configuration options are endless. Lots to learn!
