Discussion topic: Unable to disable Sky Shield
This message was authored by: moonechild
Hi there, I'm trying to disable my Sky Shield but it won't work on the Sky app or on browser. Getting an error every time I try. Could someone please let me know how I would go about disabling this?
Re: Unable to disable Sky Shield
@moonechild  The easy way would be to give Sky a call and see if the agent can get into doing this for you and if not then can escalate this further for you.
This message was authored by: Al123
I have the same problem did you get this sorted?
