07 Sep 2021 09:43 PM
Hi all,
I've been sitting here for the last 5 hours wrecking my brain on how to getting this to work.
I've moved and now have a SKY FTTP connection and my understanding is that I should be able to connect my ASUS AC5300 router directly to the ONT socket.
I've set WAN connection type to automatic IP, added my option 61 details and changed my IPv6 connection type to native.
I've tried with the latest Merlin Firmware as well as the official ASUS firmware.
Despite copying other peoples settings, I just can't get it to work.
HELP!
08 Sep 2021 12:15 AM
If there are 2 WAN ports for the Asus router then the information needs populating in both WAN interfaces for DHCP Option 61 details and DHCPv6 PD (native) for IPv6 in the router interface.
08 Sep 2021 07:29 AM
08 Sep 2021 07:48 AM
The Asus router has dual WAN and even though you are only using 1 WAN port to connect to the internet, both WAN ports need the information for DHCP Option 61 and DHCPv6 PD fulling in for the Asus to connect successfully via the Dual WAN feature option we have found on the Sky community.
08 Sep 2021 08:53 AM
All right, I turned on Dual WAN , set WAN as my primary, Ethernet LAN as secondary with LAN Port 1 and Dual WAN mode as Fail over and 'Allow failback' disabled.
On the WAN tab, I selected both profiles/ wan types and populated them with the option 61 information.
Am I correct in assuming that despite the DUAL WAN I only need to connect the ONT with the WAN? Because I still don't have a connection. However the internet light on the router is no longer red but simply completely off.
What am I missing?
08 Sep 2021 08:59 AM - last edited: 08 Sep 2021 09:01 AM
the value in the option 61 box doesn't look right to me
try using 0123456789ab@skydsl|foo
08 Sep 2021 09:04 AM
dual wan is set to off for me 😀
08 Sep 2021 09:12 AM
Used those option 61 details for years but changed to your suggestion -> no luck 😞
08 Sep 2021 09:18 AM
It looks okay what you have set up for DHCP Option 61, and the DHCPv6 PD. I'd suggest you do a factory reset of the router and populate the information again and see if that allows a connection?
08 Sep 2021 09:20 AM
check the basics and try another network cable
08 Sep 2021 09:54 AM
Tried both of your suggestions and still says "Your ISP's DHCP does not function properly".
The router should be in Wireless router mode correct?
08 Sep 2021 10:03 AM
i had mine in ap mode and wireless mode so shouldn't matter
my setup is ethernet from ONT into the wan port on the router and then the option 61 details i pasted above. ip6 was off when I first did mine as I didn't realise it would be off. You could try that and then enable afterwards?
08 Sep 2021 10:04 AM
the other thing to try is power off the ONT, leave for 2 mins then back on
08 Sep 2021 10:47 AM
Tried that too, at this stage I feel like giving up.
Maybe my RT-AC5300 is just not compatible and too old.
Shame considering the cost...
Thanks both for trying though. Do appreciate it!
