Discussion topic: Testing Broadband speed
This message was authored by DeanoCridland1977 This message was authored by: DeanoCridland1977
Hi, just moved to full fibre broadband and I don't think I'm getting the speeds promised. I want to test but I also want to use a tool recognised by sky. I'm currently using Googles built in speed test but can anyone tell me the one Sky recognise please?
many thanks..
Re: Testing Broadband speed
@DeanoCridland1977
The best way is to run a speed test on fast.com using an ethernet connection to the hub
@DeanoCridland1977
The line test in the My Sky app will show you what the line speed is for your hub.
Using an ethernet connected device at speedtest.net will show you the throughput you are getting
I am NOT a Sky Employee
