20
This discussion topic has been answered Discussion topic: The connecter does not fit the wall socket
This message was authored by: Luctram
Hi everyone
I just moved house so I changed the wifi address and today my wf will be activated but the connection between the wifi and the socket is on the wall it doesn't fit so what should I do?
This message was authored by: jamesn123 Answer
Re: The connecter does not fit the wall socket
@Luctram
Ah I see now.
You need a microfilter, they can be had from almost any local or online electronics store. Here is an example from Amazon.
I am NOT a Sky Employee
Hi @Luctram
Struggling to understand what you mean. Could you post a photo?
Avatar for Luctram
Thanks for your question, could you please show me how can i find out where's post pictures and video
Avatar for Luctram
Avatar for Luctram
@Luctram
Ah I see now.
Avatar for Luctram
@jamesn123 wrote:
@Luctram
Ah I see now.
Oh, I don't know about that, thanks for you help. Do you think it will be fit with mine
@Luctram
A plug-in microfilter converts a single BT jack socket to twin sockets: an RJ11 for data to an internet router (the purple end you are holding) and a BT socket, which is probably obsolete in your case as the BT jack socket on the rear of the Hub will be the active one.
Avatar for Luctram
 thanks for your answer, do you think it will fit with mine
Avatar for Luctram
@TimmyBGood
 thanks for your answer, do you thinh it will be fit with mine
@Luctram
Yes: all plugin microfilters perform the same function and have the same sockets.
Avatar for Luctram
@TimmyBGood @That's great, you help me a lot
thank you so much
Avatar for Luctram
hsvdgsh ksks
Avatar for Luctram
(view in My Videos)
@TimmyBGood I hope not to bother you. I bought the microfilter and installed it but I don't understand why my wifi still can't connect, do you know why?
. Hope you will answer. Thank u
Avatar for Luctram
