Discussion topic: Slow Ehternet Speed on Windows PC
This message was authored by: alan100
Hi via an ehternet cable to my Nvidea Shield I am puling 450mbs, however the same connection to my PC pulls only 73mps.
And i have disable power saving mode etc in the settings.
If anyone has had a similar problem, or knows a fix i'd be very grateful.
This is a recent thing, when i first installed it, it was giving me 400+
Re: Slow Ehternet Speed on Windows PC
@alan100 sounds like the PC is only giving a 100Mb/s rather than Gigabit. Check the networking properties as they are probsbly messed up if the port hardware supports 1000Mb/s `You can try running Windows networking trouble shooter and also try downloading and installing  an updated driver.
Avatar for alan100
yeah im not sure that is the case as i do sometimes pull 112mbps, so i don't think its limiting to 100mbps
@alan100
Sounds like there is some application running thats stopping you using all the bandwidth. A culprit is often something called killer networking
I am NOT a Sky Employee
