Discussion topic: Skymax hub capping ethernet speed to 100mbps
Message posted on 10 Nov 2024 09:53 PM
I've recently switched from Virgin to Sky & using the same wires I've used previously (and tried a couple different wires) - speeds are capped at 100mbps on both my PS5 and my PC.
I've tried changing my network adapter settings on my PC to no avail. Multiple resets of the router and also tried multiple ports. PC showed link speed was 1000/1000mbps with Virgin and only now with sky is it capped at 100/100.
No idea what to do, certain it's either a fault with the router or this ethernet speed switch that's available in Sky's router settings for their other models but not this one. Been on the phone for nearly 2 hours with nothing to offer but "I'll escalate this and get back to you".
Please help 😂
Message posted on 10 Nov 2024 09:56 PM
Re: Skymax hub capping ethernet speed to 100mbps
Edit -
I pay for 500mbps & test near this on WiFi. Problem only occurs with the PS5/PC over two separate ethernet cables
Message posted on 09 Dec 2024 11:27 AM
my hub did this, and it needed to update its software...it was then ok.
Message posted on 15 Jan 2025 06:25 PM
I've got the same - just moved to full fibre... but ports are only running at 100mbps.
How did you update the hub? I can't see an option.
Message posted on 15 Jan 2025 06:27 PM
Sky have to do it for you.
