Discussion topic: Sky max hub and sky booster 4
This message was authored by: LKIERANR
Good afternoon/Evening,
I recently upgraded my sky broadband and got sent out the max hub, all fitted all working fine and the speeds are what I wanted.
Previously I had a sky booster in the middle of the house so the wifi could reach my back (gaming) room with decent speeds, all worked fine, as expected.
But I have tried setting up the booster to the new max hub and no devices seem to be connecting to the booster. All green lights etc so all "looks" OK.
No devices in the back room are picking up the extender and the thing iv noticed is there is a separate network for the booster/extender called "skyse210",
I'm usually quite good with stuff like this but iv looked around and and can't seem to find my exact issue,
Unless from what I have read, these sky boosters are not compatible with sky max hubs.
So I suppose I'm just after clarification to whether that it is a combability issue or I'm missing something else.
Thanks in advance
Re: Sky max hub and sky booster 4
@LKIERANR
Each sky mesh only work witg a particular router
For sky max you need sky max pods as the one you have was developed by airties the max pods are plume techology
The Max Hub uses an entirely different booster model referred to as a 'pod'
@LKIERANR
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
Avatar for LKIERANR
Level 0 icon
OK, thought as much,
Thanks for the replies.
I need to try and get one of them pods then.
@LKIERANR
That would be under the terms of the 'Enhanced Wall to Wall WiFi Guarantee' part of the 'WiFi Max' subscription supplement.
Note that if Sky loaned you the current booster, that has to be returned to them along with the previous Hub.
@LKIERANR
Yep. Call sky
Contact sky on 150 from your sky landline or
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
They send ouuhe first one any more they usually do a site survey
