Discussion topic: Sky gigafast Speed?
This message was authored by mae-3 This message was authored by: mae-3
Re: Sky gigafast Speed?
@GF37
There is a known bug with Sky Q boxes connected by ethernet back to the main Sky router that causes throughput issues, but not so if they are over wireless. Can you do a sketch of your full wired and wireless LAN network for information and post it on the forum?
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
GF37
This message was authored by GF37 This message was authored by: GF37
@mae-3  Hi, I hope this is what you wanted.
@GF37
Just waiting for the sketch picture to be approved.
@GF37
The reason you have restricted bandwidth from your full-fibre connection is that you have the Sky Q box ethernet through an ethernet switch to the Sky router and you have hit a bug in the Sky Q box/router firmware that is well known. If you turn off the Sky Q box as a test completely disconnecting it from the mains power you'll find you get the full-fibre speed you spent your money on, but with that Sky Q box ethernet back to the Sky router through an ethernet switch, it will be restricted by the Sky Q box ethernet Sky router bug, unfortunately!
GF37
@mae-3 Thank you for your patience and your answer. Very much appreciated.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@TimmyBGood wrote:
@GF37
Are the speed test results in Mbs or MBs?  As the latter is eight times faster, the distinction is fairly crucial.
@TimmyBGood
Sky then throw this into the mix to confuse things even more:
"Sometimes, the only choices you have are bad ones, but you still have to choose"
@Skull+Treaty & @TimmyBGood
A bit heavy with the capitals Sky has been in its advertisement, it's surely not 10 MegaBytes per second for the Sky glass system...
And @GF37 hasn't got it this wrong Sky has a bug in its Sky Q system for the LAN system 😎
; ) - I'm sure it's 10 Mbps...otherwise loads of their FTTC customers wont be able to get Glass 😄
Although 10Mbs arriving at an address is almost certainly too little for any kind of reliability...
@TimmyBGood
With Sky's Sky Q LAN bug you really need 10Gbps from the WAN! 😉
@mae-3
We've just commissioned gigabit symmetrical on a BTnet leased line at work, and I'll bet Sky Go will still struggle.
@TimmyBGood
Well, if Sky is using the same type of technology and bugs in their headend systems they are surely adding to the additional bandwidth requirements for the internet! 😉
And Sky should read up with their suppliers that provide and design their LAN networks about broadcast storms and bridge loops, and design them correctly! 😎
This message was authored by simon194 This message was authored by: simon194
@mae-3 wrote:
@GF37
I have my Q box connected via ethernet through a switch to the hub and get around 490 Mbps on an Ultrafast Plus connection. The Sky Q bug can't be a blanket issue with the firmware.
_____________________________________________________
@simon194
Have you isolated the ethernet switch/wifi so only 1 route is being used to the Sky Q box?
