Discussion topic: Sky box has disconnected from my hub
Message posted on 05 Nov 2025 08:07 PM
Message posted on 05 Nov 2025 08:22 PM
Re: Sky box has disconnected from my hub
@Becky283 Do you mean a Sky Puck? Is it connected over wifi? Have you tried resetting the network on the Settings menu on the puck?
Message posted on 05 Nov 2025 10:11 PM
Hi @Becky283 and welcome to the forum. I have not had this issue for a long time but when I did I found the following procedure got my puck connected to the internet again.
Put your Glass or puck into Standby and then unplug both your Glass TV (or puck) and router. Leave for a couple of minutes and then plug your router back in and wait for it to finish rebooting. Once it has rebooted plug your glass TV back in and when that has also rebooted it should have reconnected to the internet
If that doesn't resolve the issue then have a look at the following links to see if they help:
https://www.sky.com/help/articles/sky-glass-no-internet-connection-osm
https://www.sky.com/help/articles/connect-devices-to-broadband-start
