13 Feb 2025 10:05 AM
Good Morning,
I switched to Sky Fibre with the Sky Max Hub last year.
Ever since the switch I have had major issues with my work laptop through which I have to connect through a zscaler tunnel.
This causes multiple issues loading sites through the tunnel, my work IT have investigated and they believe the issue is with the fibre provider (Sky).
I did not have any of these issues with previous supplier on the same laptop using the same zscaler tunnel.
I have looked over previous cases and tried all troubleshooting steps (such as Enabling UPnP - it has been enabled the whole time).
Is there anything else that can be done to resolve this issue?
Many thanks,
13 Feb 2025 01:41 PM
I have since found this post https://helpforum.sky.com/t5/Broadband/Having-problems-with-a-3rd-party-VPN-and-have-a-Hub-6/td-p/48... and requested a change.
Unsure if this is the same issue.
It appears to be the MAP-T setting that needs disabling, as having MAP-T on 1:1 ratio on the Max Hub does not resolve the issue, it has to be changed from the Sky side.
Hoping the request gets fulfilled and resolves the issue.
