Discussion topic: Setting up asus dsl-ax82u
This message was authored by: Proudy888
I've tried everything from other posts  please can anyone help with the settings I need everything I try doesn't work  constantly get "there's an issue with you isp dhcp"
The sky router is dreadful for gaming constant ping spikes and packet loss
This message was authored by: mae-3
Re: Setting up asus dsl-ax82u
@Proudy888
Depending on your broadband type, eg: superfast VDSL or FTTP the WAN type should be configured accordingly for superfast VDSL 'DSL' WAN type in the options box and DSL cable connected to the telephone socket. For FTTP with an ONT, it should be set to WAN and an ethernet connection should be used to connect to the ONT, and the VLAN should be unset.
It looks like you have the WAN type set to ethernet currently, so that needs changing to DSL.
Avatar for Proudy888
Sorry a couple of pictures didn't post
I have an ont, where do I need to change from ethernet to wan?
Also I do plug the ethernet cable into the wan socket and not one of the 4 ports don't I? Sorry I'm not very technical!
Thanks for the response!
@Proudy888
You need to set the operation mode of the asus to wireless router mode to take the dsl modem in the asus out of the equation
Plug the ethernet from the ont into the blue wan ethernet port
This may remove client identifier option field but we'll cross that bridge when it comes
@Proudy888
Also with fttp in the uk there is no vlan id. So remove 101 and untick vlan id
Thanks for all the replies
removing the VLan and chaning it to DSL has fixed the issue
