Discussion topic: Changed connection date
Message posted on 13 May 2024 11:12 AM
Message posted on 13 May 2024 11:23 AM
Re: Changed connection date
@DFaith You are not contacting customer support here, the forum i mainly customer to customer support with a few Sky staff who can only assist with certain issues.
If the date has been moved that will be down to Openreach and will have been done because the original date is no loner available, its unlikely you will be able to have it moved forward, stating you work from home will have no effect either as Sky broadband is a domestic only service and if you job requires you to work from home full time you should really be using an appropriate work/business grade service.
Message posted on 13 May 2024 11:25 AM
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable and so give a clue about the resources required.
