This discussion topic has been answered Discussion topic: Setting up Gaming Router on Sky Broadband
Message posted on 24 Nov 2024 09:37 AM
Currently trying to get my new ASUS TUF-AX3000 V2 working with my sky broadband, but I keep getting the "Network cable disconnected error"
All the advice I can find seems to be around getting it working with fibre, any ideas what settings I need to use for Broadband?
And yes, the cable IS connected...
Message posted on 24 Nov 2024 09:48 AM
@Sparktacus thst router does not appear to have a VDSL modem so cannot be connected to a broadband service over copper. You would need to either use the Sky hub to connect to the line and useca Double NAT set up or by a VDSL modem fortunately you can set up a cheap TP-Link modem router in bridge mode which is what most people do.
Message posted on 24 Nov 2024 09:53 AM - last edited: 24 Nov 2024 09:54 AM
Re: Setting up Gaming Router on Sky Broadband
For clarity, it's preferable to refer to part-fibre (FTTC) and full-fibre (FTTP)
https://helpforum.sky.com/t5/Broadband-Talk/Changes-to-how-we-talk-about-Sky-Broadband/
Both are types of broadband, and both involve fibre optic cable.
Message posted on 24 Nov 2024 10:01 AM
Connected where?
Putting an RJ11 from a phone socket into that WAN ethernet port will (kind-of) fit, but definitely isn't going to work.
