37
Discussion topic: SNR Reset
steve+284
This message was authored by steve+284 This message was authored by: steve+284
Re: SNR Reset
Is there a way to edit what I've written? I do make mistakes sometimes.
Re: SNR Reset
@steve+284 wrote:
CSP ? Customer Service Point: the passive Openreach box on the outside of the property to which the new optical drop cable is provisioned from either duct or pole.
ONT ? Optical Network Terminal: the powered Openreach box inside the property which is effectively a 'fibre modem'
Wont my old cable in my house diminish the capability of the fibre (glass?) cable.
FTTP never hits that cable: it becomes obsolete
Can the optical  fibre cable go straight to my router/hub.
No: only to the ONT.  ONT to Hub is over ethernet cable.
Re: SNR Reset
@steve+284
CSP ONT
steve+284
Re: SNR Reset
@TimmyBGood  I understand now but one last question.
Will my current router/hub still be used ?
If I've read a previous post correctly the fibre optic cable creates it's own hub, or something like that.
I appreciate you putting the pictures up.
Re: SNR Reset
FTTP requires either a Sky Broadband Hub (default) or a Max Hub (extra monthly cost)
If you currently have a Q Hub, Sky will ship one of the above as a replacement.
steve+284
Re: SNR Reset
My hub is the far left one, the one that just says 'sky hub'.
My telly box is a sky+ HD
I like that one (even though it's old) because I can recieve the free terrestrial TV channels from my satelite dish.
I've heard that you can't do that with the newer boxes, is that correct?
Re: SNR Reset
@steve+284
If you changed to Sky Q you'd need a hybrid LNB to continue getting those channels over the dish. However upgrading your broadband would not require you to change from Sky +HD
I am NOT a Sky Employee
Re: SNR Reset
@steve+284
Sky tv essentials allows to to record and receive fta satellite channels using a sky q satellite box as per @jamesn123 you'll need to get someone to upgrade to Lnb to hybrid or wideband
https://www.sky.com/help/articles/tv-essentials
