Discussion topic: One Device has suddenly stopped internet connecting to main wifi hub.
This message was authored by Paul+Curtis This message was authored by: Paul+Curtis
My laptop was happily connected to the internet and main wifi hub and suddenly today it stopped working. I tried a reboot of the laptop, the broadband hub, and forgetting the wifi on my laptop. Nothing has successfully worked.
The laptop will connect to the internet using the wifi extender we have in the home, just not the main hub.
What else can I try?
This happened about a month ago and sky sent a patch through. I wanted to see if I can resolve the issue myself
Re: One Device has suddenly stopped internet connecting to main wifi hub.
@Paul+Curtis
What extender are you using? 3rd party extenders can often be the culprit to these kind of things
I am NOT a Sky Employee
Paul+Curtis
Yes it is a third party wifi booster, would you recommend switching it off to see if this helps the laptop find the main broadband router?
thanks for your reply
@Paul+Curtis
Yes I'd switch it off for a bit and see if the problem resolves itself.
