Discussion topic: SIPL ALG
Message posted on 06 Dec 2024 12:10 PM
SIPL ALG
Anyone have any luck disabling SIP ALG? Or know a way to remove yourself. This is preventing me from working.
Message posted on 06 Dec 2024 12:20 PM
Re: SIPL ALG
If you have a business VoIP phone and a white Max Hub, the issue is likely to be related to Map-T rather than SIP ALG.
Message posted on 06 Dec 2024 12:27 PM
Re: SIPL ALG
We use Micro SIP but the guy at sky had no idea when I asked them to disable SIP ALG. I cannot make or receive calls via work due to this.
Message posted on 06 Dec 2024 12:37 PM
Re: SIPL ALG
If you have a white Max Hub, Sky requests you fill in the form linked from the pinned post at the top of this forum: it specifically refers to business VPNs but the same resolution appears to apply to business SIP phones (removal of Map-T IPv4 address sharing from the circuit)
Message posted on 06 Dec 2024 12:41 PM
Re: SIPL ALG
Not vwry good with these kind of things but I can't see a form attached?
Message posted on 06 Dec 2024 12:46 PM
Re: SIPL ALG
The link is in this post
Some of the sections won't apply to a SIP phone issue: I've suggested that Sky modifies it, as this problem is occurring more frequently.
Re: SIPL ALG
@Katie0105 wrote:Not vwry good with these kind of things but I can't see a form attached?
