14
This discussion topic has been answered Discussion topic: Router restarts
This message was authored by: Kevin_C
Router restarts
Hey. I've got an issue with my router. Using it fine all day and then it will just restart. Seems to do it once a day. Doesn't feel hot, so it's not that. The online tests say everything is fine. Anyone at Sky able to help here?
This message was authored by: Highlinder Answer
Re: Router restarts
@Kevin_C  You can find a number to call at the bottom of the link below under " Need more help "
https://www.sky.com/help/home
Re: Router restarts
@Kevin_C  Router black or white from Sky?
Avatar for Kevin_C
Re: Router restarts
It's the black one
Re: Router restarts
@Kevin_C Could you please post your router stats following the link below.
Avatar for Kevin_C
Re: Router restarts
Re: Router restarts
@Kevin_C  Do all of the lights on the router all go out and only leave the power light on. Does this happen at a certain time of the day?
Avatar for Kevin_C
Re: Router restarts
Not at a specific time, it's pretty random.
And yes all the lights go out like it's rebooting.
Re: Router restarts
@Kevin_C  Have you had the router for sometime or is it brand new? Which router do you have from the link below.
Avatar for Kevin_C
Re: Router restarts
I have the Sky Broadband Hub.
Had it for a year.
Re: Router restarts
@Kevin_C  If it is re-starting like that everyday I would get it replaced.
Avatar for Kevin_C
Re: Router restarts
Id like to do this.
But trying to get hold of anyone is proving to be a pain.
The page asks me to test the connection, then test WiFi, then if I still have an issue I get directed to this forum.
The chatbot is useless too.
Re: Router restarts
@Kevin_C  Just dial 150 on your landline and ignore the questions and you should be put through to a person at the call centre.
Avatar for Kevin_C
Re: Router restarts
I don't have a landline.
Re: Router restarts
This message was authored by: Pakiya
Re: Router restarts
Hey my router is not working
