3
This discussion topic has been answered Discussion topic: Router restarting
This message was authored by: Poppy1973
Router restarting
Hi my router is restarting lots . Never had an issue before but its getting annoying Looked at settings etc and all seems fine but every other day it drops ans reboots . Any help greatly appreciated and its the black upright one .
Re: Router restarting
@Poppy1973 assuming there isn't an issue with the connection of the hub to mains  power if your hub is resatrting on its own it implies that the unit maybe faulty. When the hub reboots the leds go out and return over a period of 5 minutes. If it is a line issue only the internet connection light is affected.
Monitor the hub but if either issue continues give Sky a call to get it sorted.
@Poppy1973
Could you post your router statistics
Avatar for Poppy1973
Thank you ,  I had a feeling it was going faulty
