27 Feb 2024 02:41 PM
I have had a ring doorbell for 2 years and it works without any problems, we have now fitted an outside camera, for the first few hours it worked well, but it's now not getting the WiFi signal, I can't move the hub any closer as it's got to be near the telephone line.
would a booster help get a signal to the camera? I'm on the fastest broadband available in my area, so we can't have fibre, we are on Superfast.
any suggestions please?
27 Feb 2024 02:44 PM
Posted by a Superuser, not a Sky employee. Find out moreDoes the camera work if you move it back closer? Its just worth making sure that the issue is definitely range
27 Feb 2024 02:59 PM
Yes it was working when we put it up, and when I move it closer it works.
when I move it back outside it says very poor WiFi or no WiFi connection?
thank you
27 Feb 2024 03:03 PM
Yes, it works when I move it closer, and it was working when I first put it outside, although it did say the WiFi was very weak
Posted by a Superuser, not a Sky employee. Find out moreYeah sounds like you need a booster then.
If you have Sky boost or Sky Max you could request one from Sky. Otherwise you could also look at 3rd party extenders
27 Feb 2024 03:17 PM
Thank you for your help, I think I'd have to pay extra for sky boost?
im on a pretty tight budget, is there any you could suggest?
can other brands still work with sky?
Im not very technical
27 Feb 2024 03:19 PM
Posted by a Superuser, not a Sky employee. Find out moreYes boost is around £5 a month.
If you put 'WiFi extender' into an Amazon search for example you'll get a good load of results that gives you options.
27 Feb 2024 03:25 PM
28 Feb 2024 08:35 AM
I have spoken to sky and all they can offer is Sky Max ? Looking on here a lot of people seem to have issues with the new white hub? And it's another £6.50 a month.
I only want to get the outside camera working, I'm not at all technical, we live in a bungalow and have had children firing catapults at the window. We have sky Q, a doorbell camera and 2 iPhones all work fine, but not the camera? It says very poor WiFi?
we are both elderly and would love to find a simple way to extend the WiFi to the camera on the front of the building?
I have searched Amazon, but how do I know what is compatible with Sky?
29 Feb 2024 09:58 AM - last edited: 29 Feb 2024 10:04 AM
Posted by a Superuser, not a Sky employee. Find out moreYeah I wouldn't get Sky Max.
If Sky wont offer you broadband boost then you could technically source a Sky booster from Amazon/eBay although I shouldnt really be saying that because the kit on there is Sky owned & the sellers should not be re-selling it. At the same time if Sky wont physically let you buy a booster from them then I don't see why not.
29 Feb 2024 10:13 AM
@Marjorie5 Also, these work very well, easy to setup and you can return it back if you have issue's.
We dont want to propose as hopefully you understand. Take a look search amazon n300 and look at 850RE. Does not like the link post.
29 Feb 2024 10:15 AM
Posted by a Superuser, not a Sky employee. Find out moreA wireless 'N' device like the TP-Link N300 extender will do more worse than good on the rest of the network. I would not recommend it.
