Discussion topic: Connected to WiFi without Internet
Message posted on 26 Feb 2024 06:06 PM
Message posted on 26 Feb 2024 06:07 PM
Re: Connected to WiFi without Internet
@Percy180 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 26 Feb 2024 06:09 PM
Message posted on 26 Feb 2024 06:11 PM
@Percy180 I have escalated your post to Sky who may be in touch with you regarding this via a private message on this forum or an email to you, both of which will invite you to a private chat.
More information about this process can be found in the link below.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Message posted on 26 Feb 2024 08:22 PM
Not sure if this is the same issue as mine but my internet went down on Friday night, no lights whatsoever and no issues in my area. I'm not sure if this will help you as I have an older box but my partner changed the micro filter attached to the box which attaches to the phone line and it worked. If u have a box which Connects to the phone line try swapping out the cable or Changing the micro filter.
Message posted on 27 Feb 2024 05:33 AM
@jennifer1620 Useful piece of info for you, micro filters can sometimes go bad as you have found out,
And if this is and should be plugged into your master telephone connection point, and if using any other extensions etc filters would also be required on those if phones connected, you should consider having the old master socket replaced. The new modern master sockets have a far better filter system. Just some info for you.
Message posted on 27 Feb 2024 09:03 AM
Thanks for escalating this. We’ve sent @Percy180 an invite to chat.
Message posted on 29 Feb 2024 09:13 AM
We are still looking to help you @Percy180 . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
