59
Discussion topic: Returning sky broadband hub
Re: Returning sky broadband hub
@laurenbh1If you need to contact Sky this can be done by dialing 150 on your landline, when asked the nature of the call say " Return Sky equipment ". But if this does not get you through to speak to someone, you can try again by saying " Technical ".
Do not hang up even when asked to do so and stay on the line.
This message was authored by Diana+N This message was authored by: Diana+N
Re: Returning sky broadband hub plug
Do I have to return the plug too? It doesn't fit in the box.  Thanks
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@Diana+N
You can print off the labels for the returns by clicking here
Not 100% sure if you'll get away with not sending the plug back too.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
Thanks. I've got the return box and the labels, but not sure it will all fit in!
This message was authored by Miss+Paulette+gil This message was authored by: Miss+Paulette+gil
i wish to send back mt hub but i have no label please send me a label that i can print off
Paulette Gill
This message was authored by Daniel0210 This message was authored by: Daniel0210
@Miss+Paulette+gil You aren’t talking to Sky. This is a primarily a customer helps customer forum and I’m afraid Sky won’t contact you as the result of your post on here.
Please read the post two above yours which includes the link.
▪️ I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
@Miss+Paulette+gil You can print off the labels for the returns by clicking here
This message was authored by fizzdisco This message was authored by: fizzdisco
Paulette Gill
You can print your own label via this page:
https://www.sky.com/help/articles/return-tv-broadband#need-a-hand
This message was authored by philip230800 This message was authored by: philip230800
Hi, we have upgraded and I need to return the old hub but don't have any returns documents.
Thank you.
@philip230800   You can print off the labels for the returns here https://www.sky.com/help/articles/return-tv-broadband
Remember to keep your proof of posting.
This message was authored by Sky+return This message was authored by: Sky+return
I've sent sky hud back so don't ask me again I'm not with sky now so don't leve any text
@Sky+return
You aren't telling Sky anything here as we are customers like you. If you are getting reminders to return equipment you should ring Sky. Hopefully you've kept your proof of posting.
This message was authored by No12 This message was authored by: No12
I have received a flat-pack box to return my gun in... but I have the original box for the hub.
so do I just abandon the better packaging and throw it into the crap box?
surely this is one of the occasions where I should have got a bag instead?
seems daft to have bespoke packaging for it which I can't use to return it in.
I'm sure they're saving money somewhere... but it would also surely be better to get kit back that still works and could be reused... I'm not convinced that will be the case here.
Crikey hub got changed to gun...
bit extreme that Sky.
@No12
The thing is we usually state that if the packaging hasn't arrived you can use any packaging as long as it's secure. Whatever packaging you end up using you may want to put a note inside with your account number and a list of equipment that is included.
Remember … Keep your proof of posting safe and indefinitely and if you use Royal Mail’s collect from home service, keep a record of the tracking number.
