Discussion topic: Return address for booster?
This message was authored by: CFS1962
I've upgraded to Max broadband and I need to return two sky WiFi boosters. I've spend most of today trying to find the address to return the product to Sky, but with no luck. Can anyone advise which address to return the products?
Re: Return address for booster?
If you need to return the booster then Sky will send the packaginbg out to you so it should appear on your account here:
https://www.sky.com/ordertracking
If nothing appears then  you can use your own packaging and print your own return label via this link:
https://www.sky.com/help/articles/return-tv-broadband
Add a note inside with your account number and a list of equipment you have included.
Make sure you get and keep proof of posting when sending this off.
