Discussion topic: Sky pod
Message posted on 26 Mar 2026 02:51 PM
Sky pod
Message posted on 26 Mar 2026 03:18 PM
Re: Sky pod
If the light is blinking it hasn't paired with the hub, so there won't be any improvement in WIFI speed.
Message posted on 26 Mar 2026 03:26 PM
Re: Sky pod
So that means that does not pair. Because I've set up it several times and according to the app is connected and still same speed. I need to solve the issue or return it back.
Message posted on 26 Mar 2026 04:40 PM
Re: Sky pod
@Akasha try setting up,close to the hub oncecconnected move it no more than hallfway to where you need the boost. See here for more https://www.sky.com/help/articles/sky-wifi-booster-setup-max-pod
