Discussion topic: Red light on BT box
This message was authored by: HarryS9
Red light on BT box
I've phoned up and was told to reset my Sky router but it has not solved the problem.
Re: Red light on BT box
@HarryS9 What RED light is on for the BT box that you call it, there are names below or above the red light!
Avatar for HarryS9
The red light is the fault light. I will fit the Sky wi fi repeater however there will still be the red fault light on the Openreach box.
@HarryS9 There are a few different versions of the OR ONT modem, but they all have various lights and depending on what you have it may or may not be a major fault condition, easiest if you just post and attach a picture off your unit if you wish the Forum to say what you expect! If it is the one with the word Fault, bottom of the box middle light, then it is more than likely just the BBU batteries that are done, and they do not stop the unit from working as long as the powersupply is good! Batteries can be changed out, replaced and you will no longer get that Red fault light up!
Avatar for HarryS9
Thanks for that. Is it a Sky job to replace the battery?
@HarryS9 have a look at the video below see what you think, you would need to get sky to organise anything that has to done, and would not think that it would be free in the slightest, batteries can be bought from the likes off B&M, amazon etc no doubt if you feel up to it.
BT Openreach Fibre ONT - How to replace Battery Backup Batteries for phone line
Avatar for HarryS9
Brilliant Jim. Many thanks
