Discussion topic: Option 61 or PPPOE - Sky FTTP 500Mb
This message was authored by: rjbarker84
Hi,
Can anyone let me know which is the suggested authentication method when using a third party router in Ireland? I'm trying to help my dad set up his router but I'm in the UK.
My understanding is that PPPOE is for ADSL?
Also does Sky Ireland using the same option 61 credentials as UK routers?
Re: Option 61 or PPPOE - Sky FTTP 500Mb
@rjbarker84
Sky Ireland do use PPPoE whilst Uk use PPPoA for adsl and dhcp option 61 for fttc and fttp
What router does your dad have
The credentials are
Username       anything@skydsl
Password        anything
VLAN ID           10
Avatar for rjbarker84
Unifi UDM
@rjbarker84
Then definitely PPPoE using the following
Password anything
VLAN ID 10
This message was authored by: sciritai
Thanks a lot, these settings worked after several days of debugging.
I had to restart the UDM Pro after saving the settings.
I also have the UDM Pro connected directly to the ONT, no Sky Router in between.
I'm in Ireland.
Attaching a screenshot to help others in futureScreenshot 2025-07-27 at 15.49.42.png
