2
This discussion topic has been answered Discussion topic: Purple cable not plugged in?
This message was authored by: MammaZo
Hello, we recently had Sky superfast internet fitted, there is a purple cable in the router but it wasn't plugged into the new white box that open reach installed, should it be plugged in?  Thank you 🙂
Re: Purple cable not plugged in?
@MammaZo
If the 'new white box' has LEDs on it then it links to the Sky Hub over ethernet and the other cable isn't required.
@MammaZo
Avatar for MammaZo
Thank you so much for your help 🙂
