Discussion topic: Problem with new broadband
This message was authored by: Deb1321
I recently upgraded my broadband but since then I haven't had use of my ring door bell it's says poor WiFi.
im not happy at all with the new package - I can't even use my sky app there is a message about signing  in I've never had before
Avatar for Deb1321
Level 0 icon
Re: Problem with new broadband
Please confir
 you received my first message
This message was authored by: Me134
@Deb1321 wrote:
Please confir
We're only other customers here, like yourself.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
@Deb1321  You need to give the communuty more than 3 minutes to post a reply, this isn't a live chat service but a customer helps customer community.
As the doorbell is the wrong side of a presumably double skinned walled that's not an unsual issue.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
