1
This discussion topic has been answered Discussion topic: Port opening not working
This message was authored by: Scimitargtv
Followed the process to open 2 specific ports my residential alarm needs but Ping.eu still says they're closed, sky stream router rebooted, deleted port forwarding rules, rebooted again, readded the ports rules still no change ???
This message was authored by: jamesn123 Answer
Re: Port opening not working
@Scimitargtv
Ports will show as closed on a port checker unless there is an active service accepting connections at the end of the port. This will likely not be the case with an alarm system, so although you've opened the ports they may not show as 'open'.
I am NOT a Sky Employee
@Scimitargtv
