147
Discussion topic: PPPOE codes for connection to third party router
This message was authored by Daniel82 This message was authored by: Daniel82
Re: PPPOE codes for connection to third party router
@mae-3
This message was authored by Chrisbarry This message was authored by: Chrisbarry
Help needed!
I have just purchased a Synology router and tried to set this up thinking it would be an easy process.
I have followed the steps mentioned above with option 61 but once I try to continue it fails to connect to the Internet.
Any ideas would be greatly welcomed.
Option 60 - name@skydsl
Option 61 - password
This is what I did in my asus and its works
Thanks for this.
I did try that and still no luck.
Ipv4 and 6 do not seem connected.
I am using auto iP when connecting with the setting you suggested but with no luck 😔
This message was authored by mae-3 This message was authored by: mae-3
@Chrisbarry
DHCP Option 61 field should be 'anything@skydsl|anything' without the single quotes in the UK.
ROI is 'anything@skydsl' in the username and 'anything' in the password field for the PPPoE type of connection.
Thanks @mae-3
I am UK based so i dont think the PPPoE applies to me?
However, I have tried DHCP Option 61 field and typed 'anything@skydsl|anything' without the single quotes. However, when I then click to advance it will fail to connect to the Internet after about 30 seconds.
Are there other setting I need to enter?
Again, thanks for your help.
@Chrisbarry
You must leave the ONT or modem and the Sky router switched off for half an hour before connecting the Asus router once set up with the DHCP Option 61 parameter and connected to ONT or modem.
And then store the Sky router away for testing fault purposes.
Will try this when I am home this afternoon @mae-3
Does it matter that I am using a synology router and not ASUS as you have mention a few times?
@Chrisbarry
The router manufacture doesn't matter in this respect.
Well I tried this and still no Internet connection.
These are the images I have taken:
@Chrisbarry
If you are connecting by an internal router modem or standalone modem have you set up a VLAN of 101 for modem or router WAN port? If it is an ONT that you connect to then this isn't required, eg: the VLAN should be unset.
@mae-3
I have an ONT modem I believe as shown in the image.
This is then connected to the synology router.
I am just trying the turn off for 30 minutes again to see if that works for.the second time. 
@Chrisbarry
Everything looks good with the DHCP Option 61 field but it may be worth putting something in the hostname field, eg: 'home'.
I have done as you have suggested but still with no results 😔
