Discussion topic: Our internet signal keeps dropping out.
This message was authored by: Simon6060
We keep losing internet temporarily. The internet light on the hub goes orange and we lose signal. It happens several times a day.
Re: Our internet signal keeps dropping out.
@Simon6060 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Avatar for Simon6060
The broadband test shows everything is fine. But, of course, I can't run the broadband test at the point when the internet signal drops out. So I don't know what to do.
@Simon6060  Why cannot run the broadband test when you are having the problem?
I run the broadband test from the Sky app, which doesn't work offline when the internet is down.
@Simon6060  It works on mobile data without any issue.
This message was authored by: imy1
I have been experiencing the same issue recently. Internet connection drops several times a day. The broadband light turns orange and then after a minute or so back to green, reconnects. 😞
I live in a mobile signal blind spot.
@imy1   Yes, that's my problem too.
This message was authored by: Nit1980
I'm having he same problem for the last few days and it is becoming very frustrating now. Sky broadband test no good. It detects an error then tries to fix it and by then the light is back green and says problem fixed. Its not fixing the underlining issue though.
@Nit1980  I think I'm going to ring them tomorrow. 😬 I'll let people know how I get on.
@Simon6060  You could ring them tonight they are still open and get this looked into for you.
@Highlinder  Thanks but busy tonight. Will have to be tomorrow.
I called Sky this evening g and explained this happens often. They did a check on their system of my router over the last month and said it looks faulty. I have an engineer coming tomorrow with a replacement. Like I said to Sky I don't pay over £80 a month for it not to work. The employee was extremely helpful best one I've spoken to in years.
This message was authored by: 9999999999mmm
Its happening to me too. Same issue with intermittent, fairly regular outages. It is not reliable.
