Discussion topic: Open reach fibre box not working
Message posted on 31 Jan 2025 09:18 PM
My internet suddenly dropped this evening with no warning. On inspection the openreach box has no lights on, attempts to turn off and on again do nothing. Cannot connect to the phone plug as I have no ethernet adapter.
Broadband checker is still saying it's working as it was working perfectly at that time (last refresh was at 4pm)
Message posted on 01 Feb 2025 03:27 AM
Re: Open reach fibre box not working
@WilsJDW
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
