6
This discussion topic has been answered Discussion topic: Older openreach box
This message was authored by: Dazk89
Older openreach box
Just moved into a house that was previously owned by an old lady, there's an openreach box however there's no power cable and it's definitely not the newer ONT boxes with what looks like the small puck attached to the wall. Just wondering how I get this changed or if this will work with the full fibre gigafactory if I can find a power cable.
Thanks for any help or advice 😃
Re: Older openreach box
@Dazk89
Yes, that is an ONT.
@Dazk89
If it's a VDSL modem (typically Huawei brand HG612) rather than an ONT then no, it cannot work for FTTP.
@Dazk89
What is the labelling on the LEDs?
Avatar for Dazk89
Tel1 PORT1 LOS PON and POWER are the words above the LEDs.
Avatar for Dazk89
I got the box off the wall and it is a HUAWEI Echolife  HG8110H-20
@Dazk89
PON or Passive Optical network does suggest and ole ont
Call sky
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
In all likliehood they'll replace the whole unit
@Dazk89
