Discussion topic: OCTAPLUSUK IP'S GEO LOCATION
Message posted on 19 Dec 2023 07:31 PM
Dear Sky Team,
We have been in touch with several support engineers over call and forum discussions. However the issue is not resolved and we have thousands of customers suffering due to sky not adding our IP's to their databases and the geo location for our IP's is not corrected. All major IP databases update everyweek including BBC.
Kindly request a senior NOC person @Chloe-W22 add the below IP's in your database and country: GB
89.21.65.0/24
128.127.149.0/24
128.127.150.0/24
154.56.232.0/22
154.56.240.0/21
191.101.24.0/24
Kindly treat this most urgent.
Many thanks,
Gladstone
CEO - Octaplus UK
Message posted on 19 Dec 2023 07:37 PM
Re: OCTAPLUSUK IP'S GEO LOCATION
@OCTAPLUSUK
I’m afraid you are talking to customers here not Sky Customer Services.
Message posted on 19 Dec 2023 07:47 PM
hi @OCTAPLUSUK
As @Daniel0210 points out we are primarily customers here - although I guess you may have realised by including @Chloe-W22 in your post.
Needless to say I think you will find that such a change will need to be requested in a business to business communicaton channel where identities can be confirmed etc. rather than through a public forum like this
Message posted on 19 Dec 2023 09:34 PM
Hi @OCTAPLUSUK,
I'm sorry to hear you're having issues, could you confirm what product your customers are experiencing the IP Geo-Location with? This is a TV on screen message can you confirm if it's Sky Q, Sky Glass and/or Sky Stream and I can get in contact with the right people 🙂
Message posted on 19 Dec 2023 11:58 PM
Hello Chloe-W22,
Thank you for your reply.
This is with Sky-q application and sky stream. Users get an error saying: failed, location check failed.
I am unable to share customer information. Sky has done this before all you need to is:
@Sky ingest the below IPs and locations as United Kinddom, or advise on your Geolocation source so we can discuss with them directly to prevent this issue each time we add new IPs to our network.
@Daniel-F I have seen you have helped other ISP's resolve this issue.
Kindly add the below IP's location as UK.
89.21.65.0/24
128.127.149.0/24
128.127.150.0/24
154.56.232.0/22
154.56.240.0/21
191.101.24.0/24
2a13:740::/29
Thank you,
Gladstone
Message posted on 20 Dec 2023 10:18 AM
Thanks @OCTAPLUSUK, I appreciate your customers are reporting this on-screen message with Sky products but we do need recent examples to look into - ideally if they can contribute to this thread I will collate these and get the right people to look at it.
In the meantime could you please give me more detail on what's happening on the Sky products ie:
- Where do they see the On Screen Message (Is it watching Live TV, Downloading, accessing apps etc)
- Does this happen everytime?
- Is it certain content? (Sky channels or others)
Any other information is appreciated,
Message posted on 20 Dec 2023 02:22 PM
Hello,
The issue is with all sky products sky-q, sky cinema these all give errors out of country.
If the above pic would help you.
Our IP's need to be added to your database. You'll have done this in the past for other networks.
Link: https://helpforum.sky.com/t5/What-s-On/MTH-Networks-Geolocation-Issue/td-p/4478238
I hope this is resolved at earliest.
thank you,
Gladstone
Message posted on 20 Dec 2023 06:28 PM
I've checked the registrar for some of those IP address ranges and they are all registered in the UK.
Sky geofencing is clearly out of date and it is Sky's issue that their customer cannot receive the service they subscribe to from Sky.
If anyone comes across this thread then I suggest they ask for a refund on the services that cannot receive because all those ranges are registered in the registrar as belonging to the UK and it is Sky's error.
Message posted on 20 Dec 2023 06:32 PM
I suggest Sky use RIPE they are the registrar for geofencing purposes and are the most up-to-date information on the location of IP public address ranges, and those IP address ranges are registered with RIPE in the UK.
Message posted on 20 Dec 2023 06:36 PM
The last ip range is chile so i don't know if its an issue with the transfer of the ip ranges from abroad to the uk
Message posted on 20 Dec 2023 06:38 PM
Thank you for checking them all, @OCTAPLUSUK you should be aware that the last range isn't registered in the UK per the registrar.
Message posted on 20 Dec 2023 06:42 PM
I checked first , last and a random one in the middle but that bought up ip ranges anyway so as you say that one is not uk registered yet and from memory was xferred over in july this year. Would there be that length of delay on ripe
Message posted on 20 Dec 2023 06:44 PM
@cookiemonsteruk & @OCTAPLUSUK
RIPE is pretty quick there is a slight delay but it is up to the receiving ISP to register the IP address range with RIPE, and the surrendering, ISP or owner of the IP range.
Message posted on 20 Dec 2023 06:49 PM
FAQ for registering with the registrar:-
https://www.ripe.net/publications/docs/ripe-733
Message posted on 20 Dec 2023 07:13 PM
You say the last IP range which is an IPv6 range is not registered with the register, it is registered with RIPE in the UK? I'm not going to check them all but from what I see they are registered with RIPE, the first and last. If somebody can check them all then that would be useful and I suggest @OCTAPLUSUK just confirm those address ranges are registered with RIPE, please. 😎
