Discussion topic: No purple cable arrived
Message posted on 11 Jul 2024 04:11 PM
Hi I just got my wifi box it's the white sky box no phone
the purple cable did not come with it , am I supposed to buy it myself plus the box that the purple cable is plugged into or will that arrive at a separate date ? Will that start my internet connection ?
Message posted on 11 Jul 2024 04:17 PM
Re: No purple cable arrived
The Hub delivery is scheduled to be before the broadband activation date. If you are going to be getting FTTP installed on that date then the 'purple cable' isn't relevant.
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
Message posted on 11 Jul 2024 04:19 PM
So if I understood that correct , I don't need the purple wire for wifi only ? And I should wait for the activation date?
Message posted on 11 Jul 2024 04:28 PM
When is/was your activation date?
For fttp you at least should have received an ethernet cable which sky refer to as a conversion kit
Message posted on 11 Jul 2024 04:30 PM
It's on the 15th so that's what I'm wondering , for the wifi to start working on the 15th do I need the purple cable ?
Message posted on 11 Jul 2024 04:35 PM
What speed were you told you would get ?
The purple cable is for fttc superfast up to 80Mbps
For ultrafast you should have received a gigabit ethernet cable usually with yellow plugs.
Could you check the link @TimmyBGood posted and tell us if it says WBC FTTP
Message posted on 11 Jul 2024 04:39 PM
I have Sky broadband ultra fast 1
Message posted on 11 Jul 2024 04:42 PM
Even more confusion ultrafast 1 can be delivered via g.fast which requires the purple cable or via an fibre optic ont which requires an ethernet cable.
Message posted on 11 Jul 2024 04:43 PM
Ultrafast 1 can be either G.fast where the purple cable would be relevant, or FTTP when it is not.
Message posted on 11 Jul 2024 04:44 PM
So my question is do I have to purchase them myself ?
Message posted on 11 Jul 2024 04:45 PM
With the white box max hub it would be ultrafast via the ont so you need at least a cat 5e ethernet cable which you can buy yourself
Message posted on 11 Jul 2024 04:46 PM
Does WiFi work without THOES cables.
also what would I search to purchase the cables
You shouldn't have to as sky should supply it
Message posted on 11 Jul 2024 04:48 PM
lol I'm confused , so will thoes cables be delivered at a separate date or do I get in contact with Sky to send me the cables
Message posted on 11 Jul 2024 04:53 PM
If you have currys, dixons, pc world etc near you and you haven't received an ethernet cable by saturday go in and ask for a category 5e ethernet cable
