Discussion topic: No ont
This message was authored by Mankit This message was authored by: Mankit
No ont
I don't have an ont box to connect my sky hub. Sky said I didn't need an engineer and it's a plug and play. Will I need to buy a new cable to connnec the hub to a phone line instead?
Re: No ont
@Mankit  What kind of broadband was it that was being installed in your property? Is it superfast or ultrafast broadband?
Mankit
Re: No ont
My stupidity, I found the Ont box. I've linked it up and currently trying to set up the sky puck. Thanks for getting back to me
Re: No ont
@Mankit  Has your internet connection come up okay and is stable?
This message was authored by Roxy1997 This message was authored by: Roxy1997
Re: No ont
Hi ,I have an ont but the plug doesn't fit in so it needs changing but no engineer came to set up my internet tho I was told that on 17th I ll have an engineer coming by . I called and there s the robot giving not too many options and then putting the call off .
Re: No ont
Which 'plug'?
An ONT will typically have a power supply on a circular pin from a mains transformer, an external optical link on a green SC/APC jack and an ethernet cable on RJ45 to the ISP router.
Re: No ont
  • Sorry I m not that experienced with the terms ,but it is the ethernet one ,the yellow one (that s the one that s not fitting in)  .
Re: No ont
@Roxy1997
OK: ethernet only goes in one way round, and usually has a small plastic latch on the plug which fits a recess in the socket.  It's perhaps possible a previous resident has damaged the socket in some way, but that's hard to see with the wall-mounting.
Typically ONTs are held to the wall on a couple of screws, so it might be possible to ease it up and away from the wall to get a better look.  If you choose to do this, be careful not to exert any strain on the optical fibre going to the greel jack as that's the fragile bit.
Re: No ont
It seems being different from what I need actually ,I don t know ,they said an engineer will come and than that it s not needed for the engineer to come ,I have no idea ,an engineer would have had everything needed, do you know how can I get in touch with them to send an engineer with the right measures ? Thank you .
Re: No ont
@Roxy1997
For FTTP activation at an address with an existing ONT an installer won't be scheduled: it's left to the subscriber to connect the ONT to the WAN socket on the Sky Broadband Hub using an ethernet cable.
