Discussion topic: Connecting my hub
This message was authored by J.A.A. This message was authored by: J.A.A.
Connecting my hub
Can I connect my sky hub to the open reach socket, using my old bt lead ? The lead supplied by Sky is not long enough - it needs to be about 3 metres long in order for me to place the hub in a suitable location.
Re: Connecting my hub
@J.A.A.  If you are talking about the rj11 to rj11 cable that connects back to the phone socket then yes you should be able to do that.
