This discussion topic has been answered Discussion topic: No internet connection
Message posted on 17 Jun 2024 03:45 PM
Lost internet connection for half an hour or so... I am working from home, and had leg injury so hard to commute to the office. Can someone fix this ASAP?
Message posted on 17 Jun 2024 05:07 PM
@Yikun Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 17 Jun 2024 04:14 PM
Re: No internet connection
@Yikun wrote:Can someone fix this ASAP?
You're talking to other customers here and not Sky.
You've posted in the Sky Q (TV) forum?
Message posted on 17 Jun 2024 08:01 PM
Thank you! I contact them and will see.
Experienced connection issue a couple of times before, and it was back to normal after a few hours. But not this time...
Appreciate the your replies!
Message posted on 24 Aug 2024 02:22 PM
Hi,
mall 4 lights are green and online check says all okay however, will not connect to phones or TV at all
Message posted on 24 Aug 2024 02:28 PM
@Missyg93 Is the pnly way for you to get your connection back is to take the power from the router?
