Discussion topic: No intenet
This message was authored by: MarkovichJames
No intenet
Morning Despite running tests I've had no Internet for 24 hours now. Restarting the box hasn't resolved the issue
Re: No intenet
@MarkovichJames
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
