Discussion topic: Lost WiFi and broadband connection
Message posted on 05 Jul 2025 09:44 PM
Since yesterday my broadband/ wifi don't work. I have tried everything.
Message posted on 05 Jul 2025 09:51 PM
Re: Lost WiFi and broadband connection
@Solomon9 Have a look on the checker and also about the hub and lights.
Message posted on 05 Jul 2025 11:02 PM
Message posted on 06 Jul 2025 07:45 AM
@SuzieQ78 Sky's lines should be open now. If your connection is down the online tests will fail as they require the hub to answer it would help if the error message was a bit more helpful. The main usefulthing the service checker can tell you is if Sky ae aware of a fault affecting your line as thst saves you a call as the area fault will be being fixed and even if you call them they wont be able to give you anything useful like the time that work will take.
Message posted on 06 Jul 2025 09:42 AM
I have done all of that but still no joy.
