Discussion topic: No Internet connection
This message was authored by: Acjponty1
My hub is saying that there is WiFi but no Internet.
The BT openreach thing on the wall is green apart from the LOS which is red.
I've been through all of the steps including phoning 150 which sent me a text message to a link which won't work.
I'm in Pontypridd, South Wales
Re: No Internet connection
@Acjponty1
Overnight maintenance can occur between midnight and 7am so now it's passed that time, if it's still not working, use the below link to check to see if there are any outages nearby
